delete policy access-list
delete policy access-list [all-rules | list_dot_rule]
Description
Deletes previously created access list and their rules.
Syntax Description
access-list Configures access list rule model.
all-rules Deletes all access lists and their rules.
list_dot_rule Defines the access list name with optional rule name in the format list_name.rule_name.
Default
N/A.
Usage Guidelines
You can remove a specific rule or remove all the rules from an access list, or remove all access lists and their rules.
The following example deletes the access list rule"ACL1.rule1":
# delete policy access-list ACL1.ace2
The following example deletes the access list "ACE":
# delete policy access-list ACE
The following example deletes all access lists and their rules:
# delete policy access-list all-rules
This command was first available in ExtremeXOS 30.5.
Platform Availability
